Pace SkyDigital Scart to Component
Discussion in 'Sky Digital TV Forum' started by TheBigSG, Oct 11, 2004.
  1. TheBigSG
    TheBigSG
    Hi all,
    I have the Yamaha RX-V1400RDS and wish to to input the sky signal from the SkyDigital (PACE) box to the component of the Yammie. Is it ok to use a Scart to component adapter. The sky box has phono out so I will be looking at getting a Scart to component only.
    Is this possible?
    Cheers,
    Steve
  2. TheBigSG
    TheBigSG
    If not can a Scart to S-video be used?
    Cheers,
    Steve
  3. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
  4. TheBigSG
    TheBigSG
    David,
    So I can't just use a adapter cable Scart stright to component?
    Cheers,
    Steve
  5. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    no - Sky doesnt output component, it outputs RGB. Therefore if you need component video for your display then you need to convert it from RGB to component.
    hope that helps
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Just to add to what david has said Sky boxes output RGBS yammy accepts YPbPr or YUV signals these need to be actively converted between the two. a passive cable will no do this..... HOwever a £150 Panny DMR-E55 DVD recorder will. and adds DVD-R functionality...
