PACE Sky+ box "locked"
Discussion in 'Sky Digital TV Forum' started by ma6235, Jan 15, 2005.
  1. ma6235
    ma6235
    My PACE Sky+ box refuses to turn on manually or with the remote control. All I have is the red light !
    Is there a hidden "reset" button anywhere ?
    Cheers all for any advice.
  2. dangerouseddy
    dangerouseddy
    Dec 23, 2004
    36
    well try removing the power lead for a few minutes. if that doesnt work then id get it replaced/repaired.
  3. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    If you can't get your box out of standby (which happened to mine), do the factory reset: unplug, then press and hold the left and right buttons on the box itself (the buttons on either side of the select button)whilst plugging back in. keep these pressed for a while , until the circle indicator lights up green. when this happens, press select and it goes through the factory reset. wait a few mins and you should be able to power on.
    this happened to me and i managed to get the box pwered up but it would record anything as the hard drive was dead,
  4. ma6235
    ma6235
    Thanks for the info, the factory reset has worked.
    Cheers.
  5. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Note that the factory reset re-formats the hard drive and you will lose all your recordings.
    'Trade' secrets don't last long on here!
    A. Dork
