Pace MSS 1000
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Fairzo, Dec 28, 2002.
  1. Fairzo
    Fairzo
    Apr 8, 2002
    107
    16
    Still have my old Pace MSS1000 analogue box and speakers gathering dust. Is it likely to be of any use to anyone to the extent that it's worth trying to flog it on e-bay, or is the bin the best option?
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,257
    Manchester
    +753
    If it's a plain MSS1000 (without a built in actuator controller for steerable dishes), its value is somewhat limited.
    Have a look in Ebay, including checking "completed items" to see what they have ended up selling for.
    I would suspect only a tenner or so.
    The version with the positioner-control in it would be a uesful standby if you have a steerable system.
    Chris Muriel, Manchester.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    My MSS1000 served for a couple of years after I switched to digital satellite as a surround sound amp, probably the most useful piece of satellite hardware I have ever bought:)
    If Ebay only charge for a sale then you have nothing to lose.
  4. zudrick
    zudrick
    Aug 22, 2005
    7
    4
    Scunthorpe
    Seems like someone's after a pace mss 1008 which i have? send a message and i'l send more details
  5. JohnKen
    JohnKen
    Mar 3, 2006
    132
    +13
    Just on the offchance - any readers have a spare handset - willing to pay modest amount and postage. I have a motorised dish which still works - but have lost the handset and can't thus reset limits etc. I upgraded the LNB to dual around 10 years ago and fed a digital Nokia box for feed hunting to it until it died around 3 years ago, then basically moved the main Pace Box to swtich to Sky +. I was hoping to get it back in use feeding one link to the original Sky Box in a different room - but can't find the handset despite searching for hours!
    If no luck I may splash out on a new Digital box able to move the dish - the only one with 36v feed seems to be the Topfield TF5000CIP 36V Positioner Satellite Receiver
  6. plonky
    plonky
    Nov 14, 2003
    343
    Liverpool
    +12
    Ye gods, a blast from the past. Ended up giving mine away but still have the Wharfedale cubes somewhere
  7. BIG BAD BILL
    BIG BAD BILL
    Aug 18, 2004
    52
    11
    if i can remember correctly any pace mss remote will work but it has to say mss on it the prima i think was a different remote but looked the same
    the mss1000 is a great as an av switching unit.. if you don't need rgb ;)
