Pace Freeview
Discussion in 'Freeview & YouView' started by ldoodle, Oct 16, 2003.
  1. ldoodle
    ldoodle
  2. AOD
    AOD
    Feb 7, 2001
    707
    London
    +4
    There don't seem to be any reviews yet, it's a new product from Pace.
    Yep, looks nice, lets hope the software is of a better quality than the first couple of versions for the Twin recorder.
    I'm trying to find somebody other than Empire Direct with actual stock. No luck yet!
  3. ldoodle
    ldoodle
    I thought it might be new. As you say, let's hope the hardware/software is top notch. And it's a lot cheaper than some of the other ones out there!
    Would also be good to have a picture of the remote!!
  4. Pod Person
    Pod Person
    Yes it is new. The software uses much the same layout as the year old smaller pace stb according to descriptions on the digitalspy forums. The original stb software is near flawless so good thing too.
    This is the box Pace should have brought out in the first instance IMO. :cool:
  5. PhilipVass
    PhilipVass
    I was going to get it and sell my Grundig..
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Go on then!
    The DTVA is so reliable - always works.
    This new box is based on the DTVA software so should be good out of the box
    Can't comment on my IDTV as it gets the equivalent of a reboot every time you turn the TV off.
    The Pace Twin however occasionally locks up on turning on (3 times since I bought it).
