PACE Freeview HD
Discussion in 'Freeview & YouView' started by Hbostan, Dec 22, 2004.
  1. Hbostan
    Hbostan
    Has anyone tried transferring PACE HD televison recording to a PC - DVD R/RW - is this possible or am I asking for too much- Have some great documentaries and running out of space would be shame to lose them
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Pretty sure there is some sort of PC application written for this STB to allow the mpegII data to be copied onto a computer without the need for the analogue stage.
    Martin no doubt will know for sure:)
    You could also get a capture card for the PC and feed the analogue output of the PACE and record that onto the hard drive in mpegII and then edit/burn onto DVD.
    Most capture cards have s-video but I think there are some external capture devices (connected to PC via USB) that support scart. Barring that they will all have composite and rf connections.
    Also worth considering a standalone DVD recorder, prices are falling especially if you don't want extensive editing facilities or an integrated hard drive.
