Pace digbox freezing/no signal after s/w update
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Ian56, Sep 3, 2005.
  1. Ian56
    Ian56
    Jun 14, 2005
    22
    3
    Anyone else had this problem recently?
    Got an old Pace receiver thats been aok for years but since it's had a new EPG download last wed/thurs it's been showing various problems:
    First signs of a problem began with picture and sound break up for a few minutes before the picture freezes totally. Check of service menu shows box is getting no signal at all and no hard lock. Can still go through all the menu's but any attempt to access the tv guide comes up with the "No signal being received" message. Thought it might be an lnb failure but connected a Humax to the cable and can get the free to air channels no problem. So think lnb is aok.
    Done all the obvious things - disconnected etc.
    Also noticed that it takes about 30 seconds for the box to come out of standby - if it does at all.
    Haven't been able to do an auto soft update due to the above problems and the current soft is listed as 3.5.b (I think)
    So this post is just to see if anyone else is having similiar problems.
    Thanks for taking the time to read this.
    Ian.
  2. JayCee
    JayCee
    Jan 20, 2004
    22,320
    Lanarkshire
    +2,325
    Have you tried a forced software update........hold the backup button on front panel while applying mains power until all leds are lit?
