Pace 12 Volt Box
Discussion in 'Satellite TV, Sky TV & FreeSat' started by patmyhead, Jun 29, 2005.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    I have this 12 volt sky receiver that i intend to use in a motor home
    would i have to use some kind of voltage Stabiliser to stop a voltage surge?if so what do i need to get.
    at the moment the pace connects direct from the ciggy socket
    with no in line fuse
    any suggestions
    Pat
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Pat,
    You shouldn't need anything other than an in-line fuse. Try a 2 Amp.
    A. Dork
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    An inline fuse only should be OK, as long as you never use it with the engine running or the battery on charge, as the voltage on a 12V battery can go up to 18V with the engine running.
    If there is any chance of this happening, I would advise that you use a voltage stabiliser like the L17AR from Maplin which has 1.5, 3, 4.5, 6, 9 and 12VDC voltage settings, and is good for up to 1000mA (1 Amp).
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    Only if the voltage regulator on the alternator is faulty. :)
    Even with the engine running, the voltage shouldn't exceed 14.5V (approx.), which the Pace box will easily cope with.
    Nick's suggestion is good if you want total peace of mind though.
    A. Dork
  5. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,614
    48
    Lancashire
    +55
    I agree with Nicks estimate. Having spent too much time B*ggering about with cars, although not as common as 14v I've seen 17v (engine running, alternator working), and a lot more if the alternator goes faulty. I've no idea what the equipment can tolerate though. I have had one alternator fail & 'boil' a battery, but have had several fail giving low or no output. If your a worrier or the equipment's expensive buy a voltage stabilizer. Or if you've a meter just measure across the battery with a little revs to put your mind at rest. I'm tight & would just use a fuse.
  6. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    thanks for your input guys
    i have allready fried one pace box
    while it was switched on i connected the genny & turned the 240volt supply on this must have caused a surge i think, cos then pace gave up the ghost
    i will check out the stabiliser from maplins carnt afford another fry up
    Pat
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Well, at £8.99 it's cheaper than a new pace if it fries :)
  8. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    had a look at the maplins gadget it has to plug into a ciggy lighter
    problem is there ain't one i have laid (if thats the right word) :D a cable to carry the 12 volt feed to the tv cupboard where it terminates in a standard 3pin square pin 4 way scocket :eek:
    any ideas on how to install the regulator in this set up
    Pat
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You've terminated a 12V cable with a 4-way 13A socket ? That's not very safe, is it ?
    You can get panel mount and wired cigar lighter plugs. These plugs are not elegant, I know, but there's a big risk of plugging a 12V appliance into a 240V socket if you fit them with 13A plugs.
