P85-3 paranoia
Discussion in 'Arcam Owners' Forum' started by hazard, Nov 27, 2003.
Tags:
  1. hazard
    hazard
    Apr 24, 2002
    137
    Cork
    +3
    Just got my P85-3 delivered. Haven't hooked it up yet (except to apply power and see if it comes on OK)
    I notice that the SP1 and SP2 buttons on the front don't "press" at all. It is almost as if they are physically trapped by the case or something. There is no "click" like I get with the same buttons on the A85.
    When I powered it on, the corresponding LEDs did not light, however that may be because there is no signal going through yet.
    Am I going to have to send it back? Or is it something I can fix easily (where did I put that Torx screwdriver... :smoke: )
