Can anyone confirm if you can use XLR's out of the AV888 or any other pre-amp into the P777 and then out of the P777 with RCA cables into a second channel to biamp a speaker ??
I can confirm that you can not do this. It is not supported and no signal will be present on the P777's audio out when using XLR in. That should also answer your questions on issues and pitfalls.
