P7 vs P35/3 - Sound and compatibility
Discussion in 'Arcam Owners' Forum' started by sticker, Jun 28, 2004.
Tags:
  1. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    I wonder if someone from Arcam can comment on the following idea.
    Current I have the following speakers and 2 P7's
    Kef Ref 203 (front) which I will tri-amp with a P7
    Kef Ref 201 (rear) which I will tri-amp with a P7
    Kef TDM34DS (surrounds) single wire
    Kef ref 202c (centre) which I am thinking of using a P35/3 to tri amp.
    My question is, it the P35/3 good enough and compatible with the P7 for this purpose?
    Regards
    John
  2. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    John or Andy, any comments?
  3. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Hi John,
    The problem here is its a value judgement and I try to avoid doing them as I am clearly biased. It will sound better with another P7 however its a lot of money and a P35 3 channel is very nearly as good.
    Having drawn out your configuration I think I would try the following.
    Try to use three channels of your existing P7 for the centre.
    So the configuration is as follows;
    L / R triamp from P7 (1)
    Centre triamp from P7 (2)
    Surrounds single amp from P35.
    Back biamp from P7(2)
    or
    you could try;
    Front L/R from P7 (1)
    Centre triamp P7 (2)
    Surrounds single P7(2)
    Back single from P7(2)
    The reason for suggesting this is that for any multichannel play back a very large amount of the information is in the centre channel so you don't really want to compromise it. i.e films - all the dialogue and centre stage action music - lead vocal and often lead instrument as well.
    Money No object, then definately get another P7, it will help pay my wages
    So as I said I am a bit biased but I have tryed to give some solutions that I think will work better. One of them is even a no cost option so you can try that.
    Regards,
    Andrew
  4. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Thanks for the Reply Andy I'll give your 1st option a go and try to get hold of a 2nd hand p35
    Regards
    John
