P7 Issue
Discussion in 'Arcam Owners' Forum' started by da95649, Nov 10, 2004.
Tags:
  1. da95649
    da95649
    Hi all,
    New to the forum, however had one of the first sets of P7 with AV8
    Having a problem with the P7, wanted to know if any knows what this is......
    ill be watching a film, then a channel will stop working , at the moment its the front right, however the centre used to cut off. On the amp the led will be flashing in Amber. To resolve the issue I have to reboot the amp.
    Is this a heat related issue?
    Any help would be great.
  2. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Welcome to the forums
    Not had the problem myself, best bet would be to get on to Arcam tech support, they will know the problem pretty quickly
    HTH
    John
  3. da95649
    da95649
    Seems like its a dodgy module, Arca going to replace it free of charge which is nice of them!
  4. davesater1
    davesater1
    May 16, 2005
    200
    My P7 has just done the same. It's out of guarantee by about 6 months. Do you think they'll fix it free of charge as it is obviously a common fault?
  5. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    All you can do is ask them. Be polite, and honest and I'm sure they will help you out. Not sure how common it is, but you can only ask.
    Andy
  6. davesater1
    davesater1
    May 16, 2005
    200
    Cheers Yogi.
    As it turns out as I registered my product I have 5 years guarantee so it's cool.
  7. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I'm not quite sure if discovering tha one other person has had an similar issue with the P7 constitutes a 'Common Fault'
    Anyway, I bet your glad you registered the product, although I don't think Arcam would have taken too tough a line on it if you hadn't.
  8. davesater1
    davesater1
    May 16, 2005
    200
    Fair point about the 'common fault'. I was getting my story ready for Arcam but yes I am glad I registered the amp.
