P7 Amp v. P1000 Amp
Discussion in 'Arcam Owners' Forum' started by gostan, Jul 29, 2005.
  1. gostan
    gostan
    Jun 27, 2005
    38
    How will the upcoming P1000 amplifier differ from the existing P7 amplifier. I have not seen the full P1000 specs, but they seem fairly similar power-wise with the P1000 costing considerably less. Is this another example of trickle-down technology with reduced prices?
  2. Audionyx
    Audionyx
    Dec 10, 2002
    667
    East Yorkie Porky
    +20
    P7 amplfier uses identical amplifer modules each having own rectification. Power comes from two 1.5KVA toroids. I believe that the P1000 uses a shared rectified PSU with one toroidal transformer. Should still sound pretty darn good but I would say (and hope) that P7 would have the edge.
    I am a bit drunk so hope that makes sense
    Darren
  3. gostan
    gostan
    Jun 27, 2005
    38
    Darren:
    You explained yourself elegantly. I will offer a toast to you this evening.
    Stan
  4. Sab
    Sab
    Dec 18, 2002
    729
    London
    +18
    Whenever you compare an FMJ unit with a corresponding DIVA unit, the FMJ unit will always be better. The FMJ units are the upmarkets Arcam units and so in the DIVA range costs would have been cut. For example look at how the DVD tray opens - on the FMJ it is very smooth but on the DIVA range it is not. (I noticed that at a demo).
  5. Sparky66
    Sparky66
    Apr 7, 2005
    71
    Sydney, Australia
    +4
    Sab,
    I have had the opportunity to own both the Diva DV79 and Fmj DV29, and to be honest they seem to feel,work and display beautiful pictures identically - even the drive mechanism on the tray moves and sounds equal.
    I'd say if both units were covered and played back to back, I would find it hard to seperate the differences between the two - to me and my system i.e. - they're that identical. Other than the DV29 having full HDMI Multichannel compliance there is little difference in their performance . Trust me - my wife reminds me about this and the price difference ,very often !!
