P4 2.6 and 2.8 Heat Output
AndyH
Established Member
Am building a PC where inside case temperature is a serious consideration.
My choice of processor is between the 2.6 and 2.8 P4's - there is only £9 difference between the two, but is the 2.8GHz going to be significantly hotter than the 2.6?
Cheers,
Andy
E
Erpland
Intel's site will tell you the exact wattage of each CPU and thermal details.
Depends on how you're going to use it but there's not goin got be much in it.
AndyH
Established Member
Thanks for replying, I did eventually find the info on the Intel site and there is hardly any difference :)
Cheers,
A.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
