DJBlade
Hi, i have the PMC DB1's as rears, and FB1's as fronts, cant make my mind up on the center speaker, the TB2 looks the natural choice, but, its big, rear ported and will be used right under my wall mounted plasma 100mm at most off the wall, then theres the DB1C, a much smaller center speaker, which will probably be a better choice for near wall use, but will look lost between the FB1's, the CB6 is out of the question at £1500.00 for a center speaker.
What do you PMC owners use, which combination ??
Simple choice if i'd bought GB1's as fronts would be the DB1C, i just cant decide..............
One of the guys on the forums replied to a similar question i posed recently in the Arcam forum that the DB1 would sound LOST between the FB1's,
what do you guys think ??
TIA.....
TIA.....
