owners of please ax750se help,relabelling a yama ax750se
Discussion in 'AV Receivers & Amplifiers' started by SILVERBACK, Sep 17, 2004.
  1. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,844
    72
    birkenhead
    +82
    just bought one of these amps today to upgrade from a sony830 but i cant for the hell of me find the option to relable my connections.thanks in advance :smashin:
  2. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,844
    72
    birkenhead
    +82
    :lease:
  3. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,844
    72
    birkenhead
    +82
    sorted.mods please delete :rolleyes:
  4. jdanielp
    jdanielp
    Jun 20, 2002
    184
    22
    Edinburgh
    +3
    by that do you mean changing what it says on the display on the amp when you switch to a certain input? (like changing VCR2 to XBOX or something?) is that a common facility on newer models generally? sounds useful if so :smashin:
  5. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,844
    72
    birkenhead
    +82
    yeah thats what i meant mate.you can change the display on the remote aswell to display the correct name for the inputs.its all done by on screen menu`s on the yamaha and after upgrading from a sony 830 i never had such luxurys lmao.
