Owl screens any good?
Discussion in 'Projectors, Screens & Video Processors' started by Mark Grant, Jun 12, 2001.
  1. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello,
    I am looking for an 8 feet wide, 4:3 electric or manual screen with Black borders.
    The Owl screens look a possibility.
    Has anyone here got one, and are they any good?
    Do they stay flat?
    (Don't like wrinkly screens)
    Anything else I should be looking at?
    [cannot afford a Greyhawk :( ]
    To be used with an 800x600 Davis DLP projector, until a JVC DILA is found.
    Thanks,
    Mark G.
  2. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Hi Mark,
    To get a projector screen to lay perfectly flat will need it to be tensioned. The best screens to lay flat are Tab Tensioned or fixed to the wall ( Framed screens ).
    The Owl Screens use a Weight bar at the bottom to tension then.
    Most screens will wrinkle a small amount, but value for money wise the Owl screens are very good.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Just to add that Vu-Tec do a 1.3 gain screen material that is VERY stiff. It stays flat without tab tensioning. It's much more than £500 though!..
    Gordon
  4. carol harvey
    carol harvey
    I would prefer a stiff one!
  5. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i have an untensioned screen .
    it is amazing what you can do with a couple of elasticated hair ties and a couple of hooks
    an tie on each bottom corner pulled on to a hook on the wall makes it a lot flater and you get a better pic
  6. Guest
    I bought an owl electric 7' screen about 6 mnths ago and I am very happy with it.
    I attached it to my living room wall and then boxed it in to look like a wooden beam.
    It uses a weight bar at the bottom and so far has no signs of rippling or creasing.
  7. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
    I used to use a 6ft Owl 4:3 motorized and never had a crease as the vinyl like material
    was quite thick.I bought a cheap Da-Lite B 8ft and it creased to bits so I made a 16:9 timber frame and stapled it to that at 7ft wide with no real problems.
