OWL or Grandview - that is the question!!
Discussion in 'Projectors, Screens & Video Processors' started by zorro, Aug 4, 2003.
  1. zorro
    zorro
    I have the Panny AE300, which is my first PJ :D
    Anywya, in the process of completing a dedicated H/C room;
    Panny AE300
    Kef Mk2 Eggs
    and a screen??????????????
    The room will be 100% dark and measures 16' x 8'
    I want a 7' electric screen - need it to go away easy as the kids will use it as a playrooom when not in "movie mode"!
    Here is what I have found so far;
    Grandview Electric 16:9 (12" extra black drop) 80"x45" for £485
    OWL Electric 16:9 (12" extra black drop) 85"x48" for £849
    Any recommendations on these 2 or seen them any cheaper??
    So, any views - I CANNOT decide!!
    Is the OWL worth the extra £364????????????
  2. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    just bought the same equipment you have m8..except i purchased a 6ft OWL. Unfortunately its not all up and running yet...however...i viewed the OWL in person, and liked what i saw, hence i bought one. One thumbs up for the OWL anyway :)
  3. zorro
    zorro
    Where did you get it from, if I can ask????
  4. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    I have an electric grandview. The material seems identical to the owl as I had a good look at a 7ft owl the other week. The casing is different but the real difference is in the hanging weight, with the owl weight being a lot heavier than the grandview.
    Personally, if things arent based on a budget I would go for an owl but the granview is/has been superb for the money if you are looking to save.
    If I had to make a decision I would go for the OWL now as you'll only end up wishing you had bought it in the first place. If you dont you'll end up with a nasty dose of upgrade-itis that you will have to explain to the good lady wife
    - ergo "well, they look exactly the same to me!!!" scenario :mad:
    grandview bought here www.intoav.com
    Hope this helps somehow,
    Cap:smashin:
  5. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Nexnix are now doing their own electric screens, why not check them out on their website. A 2m one is under £400 if I recall correctly.
    Cheers,
    Cal.
  6. zorro
    zorro
    Looks like I will go for the 7' Electric Owl for £775 - cheapest I can get it and it seems to come highly recommended from everything I have read :smashin:
  7. Kramer
    Kramer
    A wise decision. Great screen which will outlive your next 2/3 PJs.
    :smoke:
