owl electric screens faulty?
Discussion in 'Projectors, Screens & Video Processors' started by grahamricho, Dec 8, 2001.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    658
    York
    +12
    having recently bought a projector and screen second hand,i played around with the screen,ive seemed to done something,the screen goes to far down,so far it reachs the end of the fabric and carries onpulling the screen up,untill it stops,if you turn the down screw,anti clockwise,it tries to go further down,turning it clockwise does nothing!ever so often it stops altogether!it was ok before i started playing with it!does anybody now anything about them whats inside,etc thanks
  2. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    hi,
    not sure if your owl screen is faulty.. but I have noticed that I had to wind the screw clockwise then retract the screen (move it back past the new stop position) and lower again to see where the new stop position is.. anti clockwise will lower the stop, my screen jumps down approx 2cm with every half turn...
    Hope this helps, it does sound like the stop position has been fully wound out... not sure if it is now broken..
  3. paublo
    paublo
    Sep 2, 2001
    169
    South Lanarkshire
    double post... sorry...
