owl electric screen noisey(un-cool)
Discussion in 'Projectors, Screens & Video Processors' started by grahamricho, Jan 23, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    778
    York
    +18
    i recently bought a second hand owl electric screen,it worked perfect. i was a bit excited when i got home so i dont now why but i pluged it in and pressed the button,about 6 foot of screen decended from the screen box with me holding the box in my hands! i paniced and pressed the button to wind it in and it started winding in of the pile of screen on the floor,then it seemed to jam and stop!!!!!!!!!!!it works ok now,after i fixed it to the ceiling!!!!!!should have done that in the first place!but it makes a squeeling noise while winding in!!!!!!has anybody opened a owl screen box up?and what might be the problem?many thanks
  2. James McHugh
    James McHugh
    If you take the ends off you will find the motor on one end (Mains Cable Side) and and a spindle on the other.If you take out the spindle end and try greesing it. Take note to put it back the same way and do it while the screen is in its canister.This should shut shut her up!!!!:rolleyes:
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Or play the movie louder
  4. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Crikey! - if it's making a noise throughout the film then he really does have problems:D
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    Maybe its flicking in and out of 4x3 and 16x9 mode just like an auto detect widescreen telly!
    (i'm joking by the way)
  6. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Now that would be cool:cool:
    Nano-technology, I can't wait:D
