Overscan issues
Discussion in 'Xbox Forums' started by Merx, Aug 27, 2006.
  1. Merx
    Merx
    Jul 25, 2006
    35
    I currently have a Samsung R7 26 inch hdtv. But I find that it overscans slightly like every HDTV I have used when using component for my 360.
    However, my VGA cable does not, but I find that the washed out colours and "smooth" image is not to my liking. Colours and contrast and sharpness are all far better on component. So much so its a no brainer to use component.
    I was wondering is there any way to stop the overscan?
  2. Merx
    Merx
    Jul 25, 2006
    35
    Id like to stress this is not much of an issue. Im not missing any HUD or anything in any of my games. ANd it seems that most games were designed for overscan on component
    For example. Burnout actually has a black band all the way round on VGA but it fits to the pixel on component.
    And the dead rising demo. The weapon and health sections of the screen seem to be floating out in space through VGA, however in component they fit perfectly into the corners like a HUD should. Again the HUD fits to the pixel in the corner of the screen.
  3. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    36,869
    Bristol
    +9,609
    Afraid the only way to eliminate overscan is to use VGA.
