Fat_Tony
As promised, I said I would post about the switch I got from amazon.
This is the name: Tendak 4K x 2K Bi-directional HDMI Splitter Switch 1 Input 2 Output or 2 In 1 Out HDMI 2.0 for HDTV/Blu-Ray player/DVD/DVR/Xbox/PS4 Support 3D
I finally seem to have got it working, I can get Hdr on hdmi input 2 and Psvr on input 3. There is a tiny switch on the box to change which mode I want.
It seems you need to power down the Psvr before it will find an hdr signal. I had to try numerous leads (all are correct format but I remember similar issues when I first got the Pro)
I don't think it will be 100% reliable and I've had to unplug the input lead a few times but now it's all running smoothly so ill see how long that lasts.
Definitely worth the 14 quid I think it cost.
Any questions I'll try to answer
