Overcoming dust problems
Discussion in 'Projectors, Screens & Video Processors' started by Pip_UK, Apr 12, 2002.
  1. Pip_UK
    Pip_UK
    Have just bought an air puifier/ioniser for £50. It changes the air once an hour at 56sqm. My lounge is 36sqm and on setting 3 it changes the air approx twice an hour. It clears around 99.5 of particles in the air including tabacco smoke and dust.
    Being a smoker, I have noticed a vast difference in the air quality which can only benefit my pj (11HT).
    Anyone else using one and able to give any feedback?
    I will feed back how long the filter lasts.
    Pip
  2. Guest
    Where did you get it from btw?
    Andy
  3. Pip_UK
    Pip_UK
    Argos ... where else :p
  4. Guest
    On the subject of air treatment thingys, does anyone know if a dehumidifier has a cooling effect? In summer my house get's stifling hot like a sauna and I'm sure it's cos there's a lot of moisture in the air, would a dehumidifier cool the house down?
    Andy
