Overclocking worth it or not? £600 budget
Discussion in 'PC Gaming & Rigs' started by BYF, Feb 6, 2014.
  1. BYF
    BYF
    Aug 29, 2005
    3,048
    83
    +235
    I've been looking into a new build lately for £600 and contemplating whether to build a system with overclocking in mind or not. After looking around the unlocked i5 4670k is currently around £40-45 more expensive than the locked i5 4440 and needs a Z series board (+ £10) and aftermarket cooler (£15) for good results, again adding more expense
    What I’m wondering is would it be better to go for the i5 4440 and put the extra money into a higher tier graphics card for best bang for the buck?
  2. LJx
    LJx
    May 29, 2009
    3,268
    uk
    +450
    I have that 4400, can't complain. If you want gaming performance then it's a no brainer to put the money into graphics if you are on a budget, in the lower end off the market it could make a huge difference between a game being playable or not. With a £600 budget that money would make the difference between an R9 270 and a 280 or a GTX 760 and a 770 and then some
  3. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    wait longer and save up the extra £60 is the best thing you could do tbh
  4. andiuk007
    andiuk007
    Mar 28, 2012
    6,664
    Oldham
    +4,868
    Overclocking is always worth it, ask @Yonner he will talk you into overclocking. :D
  5. bearman3784
    bearman3784
    Dec 18, 2007
    5,813
    Hitting the Eastside of the LBC
    +1,649
    Save up a bit longer if you have to, I had the same dilemma when building a few months back and would of kicked myself further down the line not spending the extra few quid on the 4670k from the start. An easy quick overclock will result in near enough a 1GHz gain over the 4440, plus the Z87 boards are generally more feature rich.
  6. TheBlueBrazil
    TheBlueBrazil
    Mar 25, 2001
    1,118
    116
    +506
    Good advice, I originally went with a non OC'able H67 MB as I only wanted to use the Intel HD graphics as this was for work stuff, not gaming (Z MB's not available at the time). Went for the i2500k processor though as the cost difference wasn't really that massive.
    After that I got a GPU, then another, then a OC'able MB and then I could OC my CPU.
    It never stops, really it doesn't.
  7. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    I haven't bothered with overclocking for years now. It is a lot easier to do these days, however, I just don't see the benefits personally. You squeeze out some extra performance and potentially significantly reduce the life expectancy of your components.
    I bought an i5-3470 with an ASUS P8Z77-V LX and probably saved well over a 100quid from an overclocking rig. I am really happy with the purchase and game happily at 1080P. Overclocking has it's benefits, but it is a lot more expensive. At stock the difference between the 3470 and the 3570 is about 4-5 FPS, some games may benefit more. Overclocked, assuming you push it to max like 5GHz will see an extra 5-10 FPS on top.
    That is well accounted for by sticking the saved money into a graphics card, which you can overclock anyway.
    Given that consoles have 1.6GHz CPU's, having a smoking 5GHz i5 CPU will likely not really see much benefits.
    Of course if you are planning to encode video or perform some CPU intensive applications, then the overclocking could be a factor. For gaming, it is a nice to have, but not worth blowing the budget for.
  8. Andyh4324
    Andyh4324
    Dec 8, 2009
    1,602
    Bit of land next to the sea
    +319
    I've not looked into OC'ing very much but I will say that when it comes to upgrade time, you will sell your old components quicker and for more money if they are the unlocked version. Whenever I look in classified threads here the K and BE editions of CPU's seem to go really quick in my experience.
  9. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Agreed, £60 is about half a tank of fuel on my car which puts things into perspective.
  10. BYF
    BYF
    Aug 29, 2005
    3,048
    83
    +235
    That's what I was thinking at £600 price point it's either an i5 4440 + 770 vs 4670k + 760.
    From the benchmarks I've seen the 770 is a good 20-25% faster than the 760, however I'm not convinced the 4670k even overclocked to 4ghz would make that back up when paired with a 760 when it comes to gaming.
    Money isn't issue, I just don't want to spend more than £600 and I want to buy components that offer the best price/performance, I don't want to spend 30% more on something that gives 10% gain.
    I have to admit though I'm not that keen on big overclocks and from past experience stability gets worse over time anyway, 4Ghz is about as far as I'd want to push a 4670K and to be honest I'm not sure if I can be bothered with it.
  11. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Don't look at what benefits overclocking will bring to the table today but what it will bring to tomorrow's gpu's. By locking out overclocking you could well be bottlenecking future gpu purchases.
  12. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    24,430
    2
    In a secret location with Jennifer Lawrence
    +11,766
    Ooh this man speaks the wise words. Buy the K version.
    Also you said money isn't the issue, screw the budget then. :)
  13. BYF
    BYF
    Aug 29, 2005
    3,048
    83
    +235
    I don't usually upgrade my GPU though, I build a system and stick with it until the next complete build and start again. You guys have given me plenty to think about, I'll have to do some more research and price things up. I've had my current system nearly five years now and it was cheap build then, so really looking forward to putting a new box together.
  14. GMC79
    GMC79
    Apr 1, 2006
    10,648
    Glasgow
    +3,178
    still on the 4870? (in sig)
  15. =adrian=
    =adrian=
    Jul 4, 2007
    17,124
    The Internet
    +7,434
    Do you have one of those Razor??
    £60 for half a tank?
    [​IMG]
  16. Tom Martow
    Tom Martow
    Oct 22, 2012
    3,876
    +2,100
    Why not get really good 680 as the 770 is just a rebranded 680 as I've been told. Let the experts confirm this but you could save more money than could be spent on other areas.
    Then in a couple of years bang in a Titan QuadForce 1200 titanium French silicon GPU card in (name may vary)
  17. BYF
    BYF
    Aug 29, 2005
    3,048
    83
    +235
    Yep, it just keeps on trucking!
    About the gtx680 these seem quite hard to find now, have seen the 2gb gtx 770 for £230 at scan.
  18. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    the 770 is better, albeit not by much
  19. Tidy_Sammy
    Tidy_Sammy
    Jul 31, 2007
    1,656
    Edinburgh, Scotland
    +225
    Another vote for going the 4670K route, same route I'm going.
  20. BYF
    BYF
    Aug 29, 2005
    3,048
    83
    +235
    Any good website suggestions for gaming benchmarks? I'm particularly interested in the performance gain in games from overclocking compared to stock.
  21. Tall_Paul
    Tall_Paul
    Dec 3, 2005
    8,567
    Kent
    +2,172
    Here's one, problem is most games are gpu limited, but there are some that are more cpu dependent.
    Intel Core i5-4670K Gaming Performance | bit-tech.net
    You can see in skyrim an overclocked 4670k give +10fps on the minimum frame rate and another 5 fps average.
  22. Chox1988
    Chox1988
    Mar 30, 2005
    16,793
    basingstoke
    +9,161
    just spend the £60, you'll only want to re-buy it later anyway if you dont
  23. DeanE
    DeanE
    Feb 14, 2004
    9,657
    +5,689
    In answer to the thread title - Yes.
  24. Sega Mega Dave
    Sega Mega Dave
    Sep 23, 2007
    9,538
    +3,292
    Free performance, it's always worth it.
  25. IRobot
    IRobot
    Jun 28, 2006
    1,886
    116
    Leamington Spa
    +1,055
    Doesn't look like "free" to me.
    For a fixed budget, i5 4440 + 770 is the wise choice.
  26. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    Technically it is not free performance, INTEL and the motherboard manufacturers have long been factoring overclocking into their prices.
    A rig to run an overclocked i5 costs at least 100 quid more than to run at stock. If you are running at stock, then you can save up to 100 quid on the motherboard and use a stock fan, which saves you potentially at least 30 quid.
    That is at least 130 quid outlay to get 0-10% more performance, depending on the task, not really all that cost efficient. Not to mention the extra costs in electricity and potential life expectancy of the chip. Don't get me wrong, I am not against overclocking, I think it is fun to do. However, it is not free performance. Many years ago it was that, however, overclocking is now mainstream and the manufacturers are aware of that and price for it.
  27. Tall_Paul
    Tall_Paul
    Dec 3, 2005
    8,567
    Kent
    +2,172
    But then you have to also consider the 4670k is faster than the 4440 to start with, it's hard to find benchmarks to compare but here's one Intel Core i3 4330 / i5 4440 review: affordable Haswells - Benchmarks (HD 7970): Hitman Absolution (1920x1080 High) | Hardware.Info United Kingdom
    57.1fps for the i5 4440
    64.2fps for the i5 4670k
    Then add on the extra 10-15% of an overclock and the extra bit of money is worth it. Don't take into account the cost of the cooler, as you'll want to spend £20 on a proper cooler anyway even on a i5 4440, the stock one is a bit rubbish and not very quiet.
  28. Sinzer
    Sinzer
    May 25, 2002
    5,829
    +1,120
    I have run two Intel Stock coolers on my E8400 and my current i5-3470. Scratch off the thermal paste and apply your own and they run fine. I replaced the stock on the E8400 with an Artic7, just because I liked the look of it. However, the i5 stock cooler has stayed, it is dead quiet (I only hear the GPU fan) and keeps the stock i5 at below 50 degrees, during gaming. Not sure what the i5-4440 cooler is like.
  29. Tall_Paul
    Tall_Paul
    Dec 3, 2005
    8,567
    Kent
    +2,172
    I have a stock cooler on my 3570k, running at stock speeds and yeah it's OK, but it's not silent. £20 spent on an aftermarket cooler is well worth it IMO. I haven't done it becuase I have an air cooled GTX580, which is definitely not quiet at gaming temps :rotfl: however if I had a silent GPU I'd hear the cpu cooler a lot more. :smashin: My CPU with the stock TIM can hit high 60's in a warm room above a 580 running in the 70's.
  30. BYF
    BYF
    Aug 29, 2005
    3,048
    83
    +235
    Only other benchmark info I can find is this one
    Conclusion: Performance Per Dollar - Best Gaming CPUs For The Money: January 2014
    Although it compares the 3330p, (the 4440 is the Haswell version and slightly quicker) and it can stay within 90% of the performance of an i5 4770k in those games.
    From looking at the 4670k benchmarks linked earlier on, when overclocked to 4.6 ghz it's about a 10% improvement in most games for min frame rates and nearer 5% for avg frames. I wouldn't want to overclock that far though so at 4ghz gains may be half this.
    At stock speeds the 4670k gives around 5-10% higher avg frames than the 4440, overclocked to 4ghz I think 15% is around the most likely gain at best.
    The problem is the 4440 can be had for just over 75% of the price of the 4670k (£130 vs £170), add on a cooler and I'm looking at £60 and that's assuming I can get a Z77 series board for the same money as an H77, I could even save another £10-£20 by going for B85 board.
    With an extra £60+ saved I can buy a 770 or R280, these are about 25% faster than a 760, so I could end up with a 4440 based system with no overclocking that's 10% faster than an overclocked 4670k system.
    All of this is theoretical of course and many benchmarks aren't real world but the 4440 system does look good at a fixed price point.
