sykotik
I have just been playing around with a little bit of over clocking on my PC
and after following this
and only changing what was show
CPU ratio to 44
CPU ratio set to fixed mode
CPU core voltage to 1.140
nothing else was changed
i have gotten to 4.4 mhz
i have ran aida64 for about 45 mins and all seemed to be OK
no crashers , lock ups , or any-thing's
now looking at the 1st picture and at aida64 ( in blue) it says that the "core voltage" is at 1.152v
but looking at the cpuz ( red n black bottom left in the 1st pic ) it says that the "core voltage" is at 1.138
so is it normal to have different amounts showing ?
but i set the cpu core voltage in the bios to 1.140
also , i think i heard or read that 1.130 is the safe level to be at ,
so have i set the cpu core ratio to high ?
should i change it down to 1.130v
will it make any difference to getting a stable OC putting it at 1.130 ?
all temps were good never went above 66*c for the test which was about 45 mins long
i will run the test again tomorrow for a good few hours , to see if it stable
is there anything else i should be doing to make sure that the PC is stable at this 4.4OC ?
CPU ratio to 44
