Over 4 controls at once?
Discussion in 'Playstation Forums' started by Bomer, Jan 21, 2008.
  1. Bomer
    Bomer
    Dec 2, 2007
    266
    +19
    You can connect 7 controls to the ps3 at once can't you?
    How do you know which controls are 5 6 and 7? just have to use it and figure it out?
    And, can you connect more than 7 controls... if you're using a USB hub too?
  2. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    Yes you can connect 7 controllers at once. I think when you push the PS button it will tell you the number of the controller. ;)
  3. _cashman
    _cashman
    Sep 4, 2007
    75
    11
    +5
    It will flash up the lights under 1 and 4 for controller 5, 2 and 4 for controller 6 and 3 and 4 for controller 7. Easy peasy :D
  4. shaun1208
    shaun1208
    Jan 3, 2007
    915
    28
    Aberdeen
    +85
    You can tell on the controller by the leds,
    controller 5 = led 4 and led 1
    controller 6 = led 4 and led 2
    controller 7 = led 4 and led 3
    hope this answers your question.
    It would be entirely possible i reckon. but probably won't happen as developers will probably go on the assumption that people play with the sixaxis (unless own unique controller i.e. GHIII) thus only 7 players maximum.
    shaun
  5. Bomer
    Bomer
    Dec 2, 2007
    266
    +19
    Thanks for the answers guys :)
