KyleS1
Ok, so long story short, I just moved into a new house that has a built-in single gas oven. It is rubbish, even though it is Stoves and meant to be a good brand (so I have been told).
I want to replace it with an electric double oven.
I have found one on eBay to tide me over until I can afford a new one, but it is a built-under oven. If the space allows, is there anything preventing me from installing a built-under oven into a space where a built-in oven has just come from?
As far as I can tell, built-under ovens essentially have finished sides, and usually stand on their own feet, whereas, built in ovens use the cupboard/kitchen unit as their finished sides and are fixed to these units. If that makes sense...
Is there anything I am missing?
Is it a bad idea to fit a built-under oven into a built-in oven space?
