Outside build for a movie room
REJI
Not sure how to start
And more for me to log as we go
A friend of mine got me into home cinema nearly 20 years ago. One of my goals like everyone into this hobby is to have there own dedicated room.
I few years back we decided to re build the front of the house which in turn gave me my first room. This room is around 3.0m x 4.0m ,but was or is a funny shape. with the room in the house there’s not overly much we can or could do around sound proofing so I’d watch a film mrs would go up stairs and watch tv as you couldn’t do it downstairs.
On and off I’ve had builders to to quotes for garage conversation or possible other jobs to gain a different room but nothing really came of it or too expensive.
Due to a small accident someone hit the front garden wall just coming out of the pandemic.
We advertised the job and a builder came quoted and repaired the wall .on his last vist I mentioned to wife regarding putting a building up for the movie room and she told me to get a quote and go from there. The builder put in his quote and we’ve excepted.
So the job really is 3 jobs
Job 1 is to remove the garden
Job 2 is to remove the conservatory and put in external new door
Job 3 is to build the outside building
The building will be be external
3.4m x4.4m x 2.4 or 2.5 high
When finished hopefully
2,9 x 3.9 x 2x1or 2.3 not massive but around the size of the room in the house so more than enough for myself
REJI
Work started this week on the garden and should be completely out or where we need to be tomorrow 397A9E71-6D2B-432D-86EE-B7E670364BD8.jpeg31DCB6BC-3981-4B75-9E87-1826549F4C48.jpeg4BF6A379-D731-4330-BFDF-440163E93F7D.jpeg1B870404-E8C1-490E-B35A-E9C272BEFD81.jpeg3DD6308E-412F-46B8-A569-8713BBF746A4.jpeg402BE8D8-6E74-4238-A455-C32CE8FD79B2.jpeg
mb3195
Take a look at my thread to see what can be achieved with an outbuilding
Thread 'Shed of Darkness 9.4.6'
REJI
Ya cheers
I’ve have to admit I’ve read it a couple of times. it’s a lovely build ,and if this turns out anywhere near I’ll be happy.
I think it’s going to be similar but where going wooden frame to concrete block with render coat and cladding just on the front
(I say this and the builders struggling for timber
So may end up with a inner skin of concrete block rather than a timber frame)
REJI
Not too bad a day we’ve hit the depth we need to to get to .Tipper not turned up so load behind and the last load ready to go.apparently Monday morning then Monday evening.
Should have the footing made and ready for concrete. not sure on day for concrete also think all the timbers been ordered
CDFF214D-81DD-477B-90D8-250B2B25A598.jpeg9BF95A4A-58AF-450C-B516-196E52D3E78D.jpeg1B85ADBF-6CB0-4CFC-899D-B17D83286554.jpeg
Triggaaar
Given that you're digging down in the garden, why don't you make the room taller - a lot taller?
Planning permission should be from existing ground height (unless you've had to agree something specific) and making it taller won't cost much more (same foundations and floor, same roof).
REJI
Sorry not quite sure how to answer but happy with 2.5 meters my current room internal height is 2.1m and got used to like that height
GoAtmos
Good luck with the build and looking forward to seeing updates on this thread.
This sounds like it's going to be an epic build.
REJI
Thanks not sure epic definitely giving me a headache .got a update later just waiting on my daughter sending me some photos
REJI
Finally got dug out and concrete poured for footings.
concrete blocks and sand arrived not sure if this is for the retaining wall or the building but hoping for the wall.
Also collected the heat pump/air con unit for the room. Was looking into just a air con unit which looked easy enough to install but no sure if there’s going to be a fuse box directly in the room to wire straight into.The heat pump works straight off a plug so definitely easy to work with.
Only issue possibly will be that we need a 180mm drill bit to drill 2 holes.builder says he may have one
Will see ,if not can get one off Amazon I think.B1268AC6-FE03-47AD-9DE5-1BAB9309C28F.jpegAA9067B0-AD82-49F0-95ED-0559DB736EB6.jpeg313CEF0E-808E-463A-8D90-A02FB9FCDC33.jpegB79071CB-CC6B-4809-A8E0-A04354621000.jpeg1BA95F72-90DE-4B1C-AD94-172BEB55ED90.jpegD88D68CC-936A-404D-8555-6012A69B140F.jpeg6B4B8325-5026-4D1D-B757-967718CBFDE4.jpegC3CEC9CB-DEE8-4631-A5C2-10DACB8CAA48.jpegAFA74F34-3A1B-4176-98C6-905D3B4BAE8E.jpeg
Triggaaar
Nice progress.
What unit do you need outside for that air conditioner?
REJI
unit I’ve purchased non as it’s all in one unit
So just 2 big holes think 1 will be an inlet the other an exhaust port
REJI
Should hopefully look like this from outside
Triggaaar
Oh. I've looked at the option of getting air con, and the massive outside condensers have put me off.
Presumably the unit you have has some compromises compared with the split units?
REJI
To be honest I’ve know idea till it’s running.possible in a couple months. I would have gone with the split unit if it hadn’t needed to be run directly into a fuse box .
REJI
You're garage foundations are better than my house lol
Glad it's going well. Keep us posted.
Ya me and couple friends are thinking that they look a little bit on the big size
Maybe it’s the next Amazon depot
Guess we’ll find out in a couple months
REJI
And finally a little bit more movement. due to weather here it brought the job to stop last week.
So re started today so concrete footings have gone in and to be honest not sure what’s happening tomorrow so can’t really comment
REJI
In between we have purchased I few items for the room.
Down lights
Outside down lights
3x speaker hoods
Stainless steel wall mounts
60 meters of speaker cable
REJI
floor went down last Friday some style of kingspan with concrete going in on Tuesday and again the rain came so has taken an extra day to dry.
Today builders been here pretty much all day doing block work and pegs
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
Latest News
AVForums Podcast: 27th October 2021
  • By Phil Hinton
  • Published
Linn unveils latest Klimax LP12 flagship turntable
  • By Andy Bassett
  • Published
Samsung Tizen plans include cloud gaming for smart TVs
  • By Andy Bassett
  • Published
Freeview Play racks up 10 million users
  • By Andy Bassett
  • Published
What's new on UK streaming services for November 2021
  • By Andy Bassett
  • Published
