I've just purchased (awaiting delivery) the Panny 42PZ70 which as reported by a member last night does support 24hz (even though this is not stated by Panny UK)
Is there anyway I can use Powerstrip (which I've seen mentioned around quite a bit) to change refresh rates by pressing a specific keyboard shortcut key (ultimately a button on my remote) whenever I need to? I use MediaPortal for all my Video/Movie viewing...
I'm pretty sure I could set that up with my imon remote as that is so easy to add and control apps with.
I have no experience with MP or MCE remotes if that's what you're using, I have no idea how easy it is to add apps and commands with that. Does MP integrate PowerDVD ?
I would check the Powerstrip documentation as I would imagine you would be able to start Powerstrip with command line switches for different resolutions, or I guess you could add multiple Powerstrip profiles for the main Media Portal executable with Powerstrip, ie, mediaportal1.exe and mediaportal2.exe with a shortcut for each and each being a different Powerstrip profile, ie, 50Hz and 60Hz.
I haven't played with Powerstrip for a while now but I intend to as soon as I have the time so I will be attempting a similar exercise myself.
