Outputting sound on gamecube ???
Discussion in 'General Video Gaming Chat' started by snow-munki, Aug 31, 2005.
  1. snow-munki
    snow-munki
    Nov 29, 2003
    655
    +17
    I've current attached my gamecube to my TV using a RGB scart cable i bought, so the picture is great.
    However i'm planning on buying an amp soon and was wondering how do i go about outputting the sound through the amp ?
    Will i need some sort of connect from the TV to the amp ?
    thanks
  2. nismoskys
    nismoskys
    hmm, the only way i would know how to do it is if u had an a/v cable.. im not too familiar with scart cables
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  4. snow-munki
    snow-munki
    Nov 29, 2003
    655
    +17
    thanks, think that woulddo the job :)
    and very cheap :)
    edit: oh man but delivery is VERY expensive... anywhere else i can get these from ?
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    If you do a search on ebay for scart breakout you should be able to find something in your price range. Otherwise your local Maplin should be able to help. :)
  6. snow-munki
    snow-munki
    Nov 29, 2003
    655
    +17
    thanks again.
    oh I do remeber my Sony 28' Tv ( about 8 years old ) has a red / white phono sound outputs... assume i could use this instead ?
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    If they're outputs then you could almost certainly use those - I certainly do on my Philips set. :)
  8. snow-munki
    snow-munki
    Nov 29, 2003
    655
    +17
    sorry for all the questions... but then how would the red and white phono cables produce sourround sound ?
    as, aren't they just left and right audio ?
  9. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    You won't know the answer if you don't ask the questions. ;)
    The Gamecube only reproduces sound through the L&R audio too but this is generally encoded as Pro-Logic 2 which your amp can decode into surround sound usually with very good effect. :)
  10. snow-munki
    snow-munki
    Nov 29, 2003
    655
    +17
    Thanks again !!
    no more questions for now.. move along :p
