outputting HD to HDtv from PC
Discussion in 'General TV Discussions Forum' started by jedi-jae, Oct 19, 2005.
  1. jedi-jae
    jedi-jae
    Sep 23, 2005
    586
    +11
    Hello,
    Can someone advise what is the best way to properly output HD videos from a PC to a flat panel?
    I have a number of HD clips from the Apple movie site and although I can hook my PC up to my plasma and play them, I'm not really playing them at 720p am I?
    So how do I run the video to the screen in such a way that the screen will display it correctly?
    Ta!
  2. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    Depends on the inputs on your TV and its native resolution.......
    Via VGA or DVI (or even component ATI accessory) a PC can output a HD signal. VGA seems the easiest method, but it does depend on your TV's capabilities, and the age/capability of your Video Card (some laptops limited to 1024 by 768).
    I use DVI as my LCD as a DVI input, generally HDMI input will take a DVI input via an adapter, but usually with overscan. On my PC / TV combo I get overscan if the TV is set to DVI-Video, but no overscan if the TV is set to DVI-PC. The advantage is that with DVI-Video I can chose 720p50 as a PC resolution for PAL DVD's. I can set a custom HDTV resolution within ATI catalyst ultility.
    I use VLC as my player, www.videolan.org freeware, and very good.
  3. jedi-jae
    jedi-jae
    Sep 23, 2005
    586
    +11
    So I hook up my PC to my screen then set the graphics card to display at a particular resolution? My default resolution is 1024x768. what I find is that to view my desktop on my plasma I need to set the screen to 4:3, if I maximise the HD movie via quicktime I have to zoom the image to fill the plasma screen.
    How do I play the HD video via quicktime to fill the screen without having to zoom the image, which of course makes it look a bit naff.
  4. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +921
    You need to select a 16:9 square pixel resolution for your PC to know that it is connected to a 16:9 display OR you need to use a player that ignores the Windows resolution and will display 16:9 video full-screen (rather than letterboxed) even if Windows thinks the desktop is 4:3 (not 16:9).
    I run my PC 1024x576 - which 16:9 "PAL" SD. You could try 1366x768 or 1280x720 as resolutions - though depending on your video card you may need to update your video drivers or use Powerstrip.
  5. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    was just about to ask this!!
    but my laptop has a VGA out and I have a HiDef ready telly that has DVI-in and a 15P-DSUB in (is there a difference..?)
    what is the best way to plug my laptop to my telly in order for big screen gaming?
    my gfx card is a geforce2go 440mx 32meg ram, not sure of max resolution sorry
    thanks in advance
  6. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +921
    Yep - VGA is analogue RGB and carried on the 15pin D connector, DVI can carry digital video (not analogue) and also, sometimes, analogue video.
    DVI-D = Digital only
    DVI-I = Analogue AND Digital
    DVI-A = Analogue only (rare)
  7. jedi-jae
    jedi-jae
    Sep 23, 2005
    586
    +11
    Bah, didn't work, I updated my driver from Nvidia, but it doesn't have any 16:9 type outputs, even when I unticked the box so that all possible resolutions were listed rather than the ones my monitor can show.
    there is an area where I can enter an custom resolution, but when I clicked this I got a warning about damage to my PC, so I stopped. I may drop Nvidia an e-mail.
  8. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    @stephen
    my telly has DVI-I and my laptop has VGA out. so i can connect a 15pin from my laptop to my tv right?
    @jedi-jae,
    www.station-drivers.com claims to have some nvidia drivers that have output options
    havent tried myself but will at weekend
  9. smokechips
    smokechips
  10. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    Basically as other people have said, try and find out the native res of your panel - usually states in the specs in the manual - and you want to match that on your VGA/DVI output to the panel. 1366x768 usually needs to be either 1360x768 or 1368x768 due to the way gfx cards output resolutions.
  11. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    thanks everyone
    have found VGA to DVI adaptor for 2quid and cables for reasonable price too
    my panel's res is 1368x768
  12. Mandarin Man
    Mandarin Man
    Will 1366x768 TVs accept 1366x768 progressive from your graphics card via DVI or just via VGA?
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,990
    The Borders
    +3,599
    Hello all
    jedi-jae - a completely different 'option' is to install a SnaZio SZ1350 on the end of your network and let the SnaZio stream the HD clips and Output them at 720P or 1080i via its Analogue (YUV) Component Output or RGB on its Digital DVI Output.
    Far simpler than messing about with your graphics card - be it a MAC or a PC; see http://www.snazio.com/ > Products > NET DVD Cinema HD.
    Best regards
    Joe
  14. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    damn you Joe :)
    I couldn't resist and have just ordered a 1350 to hook up to my 435xde, got about 150gig of 720p and 1080i downloaded so just need to reconnect my little used wireless hub and away I go :)
    how long does delivery usually take on these from the snazio peeps, any ideas ?
    any recoomendations on cables ?, still using all original stuff that came with the XDE, and I got some IXOS component stuff lying around as I plan to use component output from the Snazio as my Arcam DV79 uses the HDMI
  15. dan1979
    dan1979
    Sep 16, 2004
    3,540
    83
    +218
    Hope you're not planning to stream HD stuff wirelessly..
  16. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,990
    The Borders
    +3,599
    Hello Radioactive man
    Not sure on the position with the 'SnazziShop' - things are moving quite quickly in the UK as far as setting up a more comprehensive Distribution and Dealer base! The Scottish end is now sorted :)
    I'd start off with your 3RCA to 3RCA YUV cables - once you have everything up and running you can always try alternative YUV cables.
    Best regards
    Joe
  17. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    ah Joe, if your suggesting you could have supplied yourself, I wouldn't have followed the link you posted :(, completely missed your sig
    as regards streaming wirelessly, It would be easier but I can always use the rj45 if necessary, or are you suggesting neither would cope with the higher bitrate of a 1080i ?
  18. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    cant recommend this unit highly enough, managed to get one lunchtime today from Joe and all is well with the exception of the ondisc DRM for Tomb Raider2, but I'm sure a little light reading will get me there.
    finally getting the benefit of my 435 after a year of ownership and cant be happier at the moment
    a few stutters streaming some 1080, but this was cured by getting exclusive access to my wireless network :)
  19. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    managed to play some HD trailers to my telly from my laptop (vga) and wow!!
    still not sure how to use internet explorer on my telly though! the desktop is like there's two desktops next to each other!
