I have a Sony KDL26T3000 tv. It is only 720p but can handle 1080i fine. I know this as my ps3 regularly upscales to 1080i and my tv recognises this and displays the 1080i picture with no problems.
When usining the tv as a pc monitor, it sets the resolution to 1280x768 with no problems, however if i try to up the resolution to 1920x1080, the screen refreshes to 1080i but then the the desktop image extends past the size of the screen and the quality appears reduced. Im guessing this is becuase the graphics card is outputting 1080p but the tv can only accept 1080i maxium resolution. Is there anyway to change the settings so that i can get 1080i resolution from my pc.
Also if this helps, i connect the pc to the tv using a dvi to hdmi cable. The graphics card does have a hdmi output but i didnt know that at the time of purchasing the dvi to hdmi cable.
Could the cable be causing any problems, would it be better using the hdmi output on the graphics card? The tv also has a pc in, its a vga socket i think, would this be be better?
Any suggestions welcome, thanks in advance.
