Outputs from STBs
Discussion in 'Satellite TV, Sky TV & FreeSat' started by eeper, Sep 16, 2003.
  1. eeper
    eeper
    Dec 4, 2002
    61
    UK
    What audio/video outputs should I be looking for/expect in an STB? I'm currently choosing between ntl and Sky+ and would like to link them all into my amp and funky new LCD display (when I get it)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    well Sky+ has S-video most amps will switch this or use an RGB>YUV converter for component switching if your amp will handle this. Both output RGB.
  3. cynicaltaf
    cynicaltaf
    NTL digital STB's tend to have either s-video or RGB outputs, as well as Composite, depending on the box version available when they install it. You could try specifying that you require a specific version when you order.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    depends on the ntl region as too which boxes are available some regions only use one type of box Cardiff only use 4000 boxes.
  5. eeper
    eeper
    Dec 4, 2002
    61
    UK
    Thanks guys,
    Do either of these providers output in 5.1? If so, can I link this thru my amp?
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    Only Sky+ boxes output 5.1
    This can be connected to any AV receiver with a digital (optical I think) input spare.
    Mark.
