N
netphreak
Hi all!
Here's my PC specs:
Asus M2N32-SLI motherboard
AMD X2 3800+ CPU
2 GB DDR2 PC6400 RAM
Skystar1 "premium" DVB-S tuner card
NVIDIA 7800GTX graphics card.
32" CRT TV with SCART, S-VHS and composite in.
One problem is that I bought the Skystar card second hand, and all cables/dongle are missing So I have the following options on how to hook up my TV:
1: From the DVI-I connector on my graphics card.
2: From composite out on Skystar
3: Buy a RGB cable kit
Alternatively, is it possible to buy a "dongle" for my Nvidia card anywhere (needed to get RGB out of the graphics card)
Is it in general better to go for TV out from graphics card or my tuner card?
Thank you for any inputs!
Here's my PC specs:
AMD X2 3800+ CPU
