output to second tv
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mattyccfc, Dec 27, 2006.
  1. mattyccfc
    mattyccfc
    Nov 7, 2006
    30
    Chester
    got sky connected to second tv via coaxial cable. however picture quality is not as good as the one to the main tv
    i've changed the channel number in the sky settings but still cant get anywhere near as clear a picture on the second tv as the first.
    main tvs 42" panny plasma, seconds a 37" samsung lcd
    would a signal booster help? or changing the coax cable to something better?
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    It will never be as good, one is connected via Scart hopefully set to RGB and 16:9 not 4:3 and PAL. The other is condensed, broadcasted as RF and sent up a co-ax as RF and in Mono. BUT do check you have made excellent connections with the co-ax plugs.
  3. barty74
    barty74
    Dec 26, 2006
    39
    11
    +5
    depends how bad the picture really is? if its grainy/snowy then you may have a connector/ cable issue, or the rf channel might clash with one used for tv transmission, if its just a clarity issue then as previously mentioned, the connections are limiting you.
  4. mattyccfc
    mattyccfc
    Nov 7, 2006
    30
    Chester
    problem solved - it was the tv!
    swapped for another panny plasma, 37" PX60
    thanks for the help
