J
jfd321
I'm new here so I hope I'm asking this question in the correct forum .
I need to show the video output from my laptop on 2 or possibly 3 tv's at the same time . I usually only need to show this on 1 TV & I connect through the S-Video output of the laptob to the Scart input of the TV . Can anyone tell me what would be the easiest method to do this using 2 / 3 TV's ? Is there something I can get like a scart block but with 2 / 3 scart outputs instead of the normal 1 or is there some other method I can use ?
Any helpful suggestions would be appreciated .
JF
JF
