Outlook Express/Freeserve query!
Discussion in 'General Video Gaming Chat' started by PoochJD, Jul 7, 2003.
  1. PoochJD
    PoochJD
    Aug 28, 2000
    11,002
    Norwich
    +1,861
    I thought I posted this query on Sunday 6th July, but it looks to have gone AWOL. So here it is again.
    Can anyone help me out please, as I have an Outlook Express 6 / Freeserve ISP e-mail query?
    Basically, I connect to Freeserve using my Panasonic GD87 mobile phone, using a USB Data Cable. I can surf the net okay, albeit fairly slow. However, I am unable to send or receive e-mails. When I press the Send/Receive button in Outlook Express, I get the following message:
    *** The connection to the server has failed. Account: 'Freeserve', Server: 'smtp.freeserve.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 10060, Error Number: 0x800CCC0E ***
    This means absolutely nothing to me, so can anyone tell me what it does mean, please, in simple-to-understand English, and also, how to cure the problem, as I refuse to pay Freeserve 50p per minute to tell me it's my PC at fault.
    I use Windows ME, if that helps.
    Thanks, in advance, :)
    Pooch
    (DVD Talk Moderator, AV Forums)
  2. nathan_silly
    nathan_silly
    Try changing the connection method (use any available) in outlook.
    Tools, accounts, mail tab, properties, connection. Choose any available.
  3. colesy
    colesy
    Dec 28, 2001
    729
    +16
    If that doesn't work you can send email directly from the Freeserve website. On their main page in the top right corner, you can login there. Once logged in you can send and receive email.
  4. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    Generally, this type of error will appear because of security settings. Make sure your settings are correct, do you have the right username and password?
    http://www.freeserve.com/help/email/freeserveemailsettings/default.htm
    Check your settings here.
    Do you use a normal landline? I assume you are using a laptop? You are definately dialling through to a freeserve number (I don't think the phone is GPRS?)?
  5. PoochJD
    PoochJD
    Aug 28, 2000
    11,002
    Norwich
    +1,861
    Hi Guys,
    Thanks for the tips. :) I'll give these a try and see what happens.
    Pooch
