outdoor speakers
Discussion in 'Home Cinema Speakers' started by siy, Aug 4, 2004.
  1. siy
    siy
    Guys - I am looking for some cheap speakers to put in the garden (or small indoor ones that I could put in the doorframe of my garage)
    Any pointers? I need to keep it as cheap as possible.
    cheers
    siy
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Do a search - there are several threads in the last year dealing with this topic.
  3. Swifttech
    Swifttech
    Terralec do these. not sure if it's what your after.
    [​IMG]
  4. Craig Sowerby
    Craig Sowerby
    Nov 14, 2002
    313
    +27
    Check out Speakercrafts "Webster" outdoor speaker, this is the coolest thing i have seen, it's a Frog!! :laugh: about £170.
    they also do rock speakers for similar cost.
  5. siy
    siy
    Excellent - nice ones
  6. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I can recomend the frog speaker it goes quite loud and sounds good. I was lucky to get one new of ebay for £40 delivered.
