Outdoor furniture restoration
GTeng
Looking for some advice please, I bought a weathered hardwood outdoor table and chairs.
I’ve cleaned it all down and gave it a good scrub, even took the pressure washer to it and it cleaned up nicely.
I used Cuprinol colour restorer gel and it looked great while it was wet, but dried quite faintly. Then I used Cuprinol clear stain as I don’t want to darken it down to oak/mahogany colours or paint it a different colour entirely.
While this looks nice in parts and exactly how I want it to look, other parts are very patchy.
Any ideas on how to resolve?
Thanks in advance 😁
KyleS1
Did you treat it while it was wet? Probably should’ve sanded it before applying a treatment. I sanded mine down last year and then used teak oil. Worked really well.
GTeng
No I left it to dry after I cleaned it, and left it to dry after the Cuprinol gel. I gave it a light sand before I stained it. I used teak oil on a spare chair I’ve got and it didn’t seem to do much so went with the stain.
Dony
Bumping this to see if you did anything further. I've a very similar outdoor table and chairs that could do with a freshen up.
KyleS1
Might be specific to your furniture. For mine, I sanded and oiled with teak oil. Came up like new. Sanding was the pain in the ass bit!
Dony
I can imagine the sanding being a pain. I've no sander so will be doing it by hand. I'm not too fazed by the table, but there's 10 chairs to go with it. I suppose I'll start with the table and see how that goes.
Probably a job for early next spring.
KyleS1
I did it by hand too. My mouse sander, or whatever they are called, was rubbish.
I never did complete all chairs... :(
