Out of phase rears. Good or bad?
Discussion in 'Home Cinema Speakers' started by JFK, Jan 22, 2003.
  1. JFK
    JFK
    Apr 6, 2002
    198
    middlands of no return
    +11
    I have monopoles for rears and reasonably happy with their sound. Would making them out of phase (changing polarity of speaker cable) give me a more dispersed wraparound effect and would it damage anything by doing this.
  2. EvilMudge
    EvilMudge
    The phase error should give a more diffuse soundstage at the rear, but you run the risk of cancelling out lower frequencies if you run the satellites out of phase with each other. Changing the polarity at the speaker shouldn't do it or the amp any harm, so experiment and see what happens.
  3. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    I wouldn't recommend it, you'll lose effect placement between the front soundstage and the rear as they'll be out of phase.
    Not a good idea.
    If you want a diffuse soundfield get some dedicated dipole speakers, the principle behind them is quite different as I'm sure you'll know - it's not as simple as having some drivers out of phase.
  4. NicolasB
    NicolasB
    Oct 3, 2002
    5,885
    Emily's Shop
    +567
    You could try aiming the rear speakers at the wall or at the ceiling, or pretty much anywhere other than directly at the listening position.
  5. JFK
    JFK
    Apr 6, 2002
    198
    +11
    My rears are B&W 302. They go down to 70htz but I have them set to small so my mains (602 s3) take the bass from 90htz and down and when I get a sub it will be sent there. Would there be a lot of cancelling frequencies by changing polarity and make all things sound very odd.
  6. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Absolutely, just try listening to a source in plain old stereo with one of your front speakers out of phase with the other and listen to how disjointed and unfocused it sounds.
    It's this kind of effect you would experience between the fronts and rears.
