out if synch sound
Discussion in 'General TV Discussions Forum' started by tufty2000, Dec 23, 2004.
  1. tufty2000
    tufty2000
    Hello, I have just bought a Sagem Axium and it is great accept that when watching DVD's The sound is out of sync as this is relayed from my player to my amp via optical, and I know that the tv does some processeing before showing the picture which means that the lips on the tv is slightly behind the sound, I cannot find any sound delay options on my sony str db930. Any ideas or am I gong to have to get a new amp with a delay option?
    Thanks Paul
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    You can buy a dedicated audio delay gadget, which has the selectable delay needed to compensate for this problem. I think there is a Sticky for it over on the plasmas forum. Check the price and see whether it is worth it, in comparison to the price of upgrading your amp.
