Our Xbox RGB scart cable.
Discussion in 'Xbox Forums' started by Mr Quint, Jul 30, 2005.
  1. Mr Quint
    Mr Quint
    Jan 31, 2005
    5,452
    7
    Amity Island (Martha's Vineyard)
    +1,521
    The Advance Scart cable that we use for RGB and 5.1, Anyone know if it will work with the 360? The port looks the same.
  2. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,798
    167
    The Wheldon Road end!
    +7,961
    Not sure as yet. The port does look very similar but it's hard to tell if it's exactly the same at the moment. I hope it does as it would be good to use the HD pack on the 360 :smashin: .
