Otoma H50
Discussion in 'Projectors, Screens & Video Processors' started by SCAMP, May 6, 2003.
  1. SCAMP
    SCAMP
    Dec 2, 2002
    35
    I am considering adding a projector to my system.
    I have found a great offer on the OPtoma H50
    but am struggling to find any performance data.
    Does anybody have any comments?
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,757
    Cheshire
    +108
    Try a different spelling - Optoma (having a P makes all the difference ;) )
    In brief:-
    4:3 panel DLP projector with a native resolution of 800x600 pixels. Features semi-long throw lens.
    Pro's
    DLP so higher contrast ratio than LCD (a generalisation) @ 800:1
    bright - 1300 ANSI is quoted
    compact - as most projectors are nowadays
    Pal progressive compatible - for future proofing
    DVI input - for budding HCPC enthusiasts
    Con's
    Some DLP rainbow effect for certain viewers - a demo is recommended
    4:3 panel format - can leave shadows above and below with 16:9 images
    Component shared with the RGB PC input
    Fan & colour wheel noise a bit higher than average
    If it will fit in your room and you don't see the rainbow effect then chances are you'll like the picture from this projector. Try before you buy though.
    Good luck
  3. SCAMP
    SCAMP
    Dec 2, 2002
    35
    Thanks this is very useful.
    My other contender is the much written about Panny AE300.
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,465
    Surrey. UK.
    +2,115
    The Infocus X1 is a similar spec, though I think it has a slower colour wheel (possibly more rainbow likely), and a white segment. It's also a lot cheaper - around £1200 or less.
    go to www.projectorcentral.com and you can compare specs directly between different machines.
    Gary.
