Re the 'Other Sats' feature of the Panasonic P42G20 model.
Wondered if any of you users can answer this question before I commit to buying one;-
It refers in the user manual that I downloaded from Panny, that there are three Sats tuneable;- Astra2 Astra 1 and Hotbird. How does it select from these? Is it using Diseq 1.0? I have a 4-way Diseq switch connected with Astra 1, Astra 2, Hotbird and Sirius. I intended to connect the output to the TV and hopefully be able to tune from each satellite. Does this TV use Diseq to select sats do you know? Or does each Sat LNB have to be plugged in manually?
I see something referring to 'Any Sats'. in the tuning setup. Does this in effect pull in all four that are connected via the Disec switch?
Thanks if can help.
Barry
Thanks if can help.
Barry
