'other channels' on sky?
Discussion in 'Sky Digital TV Forum' started by reevesy, Aug 25, 2006.
  1. reevesy
    reevesy
    Feb 20, 2005
    6,173
    +2,063
    got a question about the 'other channels' section in skys set up menu....can you add these to favorites and select the channel same as other pre programmed favorites?
    the reason i ask is all my itv channels have been shot on sky for ages (no big loss!) but i can get some by selecting the ones showing in the other channels bit...ie anglia south but as this comes up with no channel number its not straight forward to select...i have to keep going into the set up menu to select the channel.
    any idea on how you can select it via favorites or any other method.
    cheers in advance.
    :confused:
  2. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    No you have to go into the other menu (services) to access these channels.
    Cheers, Franc
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    $ky deliberately made it awkward to use the "other channels" in the same way that their boxes are crippled such that they will only handle symbol rates of 27K5 and 22,000 (KiloSymbols per second).
    Chris Muriel, Manchester
  4. reevesy
    reevesy
    Feb 20, 2005
    6,173
    +2,063
    ....there,s a surprise....
    cheers for the replys
