OT : Scart to S-Video : Black and White Picture
HEADRAT
Established Member
OK I've got a problem and I know you guys will know the answer as its more of a cable problem than a hardware problem..
I've got a MSI TV@nywhere and I know its all OK because if I connect the TV-out from my 9700 Pro (PAL_I) to the S-Video-in on my TV@nywhere I get a colour desktop
But if I try and get a picture from my TIVO using a SCART to S-Video converter (BELKIN break out box with S-Video, Composite, Audio Left/Rigth) its in black and white. If I use the composite out on the same adapter I get a color picture but I can't get it to work with S-Video..
Things I know its not :-
1. Not the S-Video cable as I've tried about 3.
2. Not the S-Video in on the TV@nywhere as if I do a straight S-Video to S-Video I get a colour picture.
I'm sure I've seen this problem posted about before but I can't find it using search..
HEADRAT
J
Jonny1973
Just because the cables connect does not mean that the signals are compatible.
Does the Tivo have an S-Video out socket or can it be set in the menus to output s-video. Sorry but I'm not familar with Tivo's.
If it doesn't you will need to convert the signal from the Tivo to an S-Video signal using an RGB Scart to S-Video converter.
I got mine for £65 from John Sim. Here's the link to his company
http://www.rgbtosvideo.com/
I believe maplin and keene do an equivalent.
www.maplin.co.uk
www.keene.co.uk
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
