OSD help
Discussion in 'AV Receivers & Amplifiers' started by mepsipax, Sep 9, 2004.
  1. mepsipax
    mepsipax
    Mar 20, 2004
    181
    +8
    Just purchased a Yamaha DSP 750SE.
    I have been attempting for the last couple of hours, to enable the 'on screen display'.
    I have a composite (yellow end) cable plugged into the monitor out of the amp.
    The other end is going into yellow video input on the front of my TV.
    I also tried inserting the cable into the video input on the front of the amp, then again to the jack on my TV, but still not accessing OSD.
    Advice appreciated
  2. mepsipax
    mepsipax
    Mar 20, 2004
    181
    +8
    I have finally sorted it out, it turned out to be a faulty lead, I swapped that and now it works perfectly.
