OS Upgrade
Nineball
Hi, can someone please tell me if it is possible to upgrade to Windows 10 for free?
I have an old laptop that is running Windows Vista and really need to upgrade it to Windows 10 if possible.
Total novice and and any help would be appreciated. Thanks
EndlessWaves
No, Windows Vista was never included in the free upgrade, only Windows 7 and newer versions.
If you're contemplating buying a copy then do check for compatibility first as it's entirely possible circa 2007-2008 hardware won't have Windows 10 drivers available.
Nineball
Ok, thanks for that. Where can I check for compatibility and how do I know if it is? I know it's probably straight forward!
Officially, there's no compatibility checker for Windows Vista to Windows 10.
maf1970
If your machine is from one of the big manufacturers like HP,Dell etc then download Windows 10 from Microsoft burn it to a disk or usb drive then install it as a clean install. These manufacturers have listed all their hardware that is compatible and given them a windows 10 license. It is not something any of them are advertising though.
Please note - please backup any personal data etc before doing so as it will wipe the drive.
Rockets
At the very minimum you will need to update the BIOS to a version known to work on windows 10. If there is no BIOS that works on windows 10 just slide the laptop off the desk into the bin.
maf1970
What is the make and model of the laptop ?
maf1970
It's quite an old one. It's a hp G60
Ah, right ! Just had a look at the spec and the honest answer is absolutely no chance. It is just too old. Sorry.
I would save your money and look for a replacement.
razy60
Or run a Linux distribution, unless you need something specific to windows.
Seems some are running windows 10 on it though.
Rockets
Often is the case with older machines, the model number is so wide and has various specs over the years it was in production.
I would guess it will come down to the actual processor on this machine. Really needs a BIOS available that is windows 10 compatible/processor for this laptop.
Without a up-to-date BIOS it's quite likely the windows 10 installation won't go past the first stage boot test let alone the second stage.
Similar threads
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
