original xbox games on the 360
jpb82
hi
i have my 360 connected to my samsung le32r74bdx hd-lcd
using component cable and picture quality is fantastic.
however when i play original xbox games on the 360 picture quality
is very disapointing.
what i would like to know is if i was to buy the original xbox and connect it to my hd-lcd will that improve the picture quality of original xbox games
because using the 360 to play xbox games on a hd-lcd is a waste of time.
thanks
stainway
jpb82 said:
hi
thanks
For original Xbox games you could select lower resolution signal (480p for example) or just switch off the HD on the connector.
