Origen ae Cases and Antec Fusion
Discussion in 'Computer Components' started by Pumauk, Sep 20, 2007.
  1. Pumauk
    Pumauk
    Nov 30, 2005
    968
    +16
    Anyone know of a place to get an Origenae S21T case from in the UK?
    Also,
    Whats the best air cpu cooler one can fit in the Antec Fusion case?
  2. superal
    superal
    May 18, 2007
    378
    28
    +95
  3. Pumauk
    Pumauk
    Nov 30, 2005
    968
    +16
    Would a Tuniq tower not fit in the antec fusion?
  4. superal
    superal
    May 18, 2007
    378
    28
    +95
    It would...if you don't put the lid on..way too tall!!
  5. GLP1
    GLP1
    Sep 8, 2005
    209
    28
    +34
    I echo Superal suggestion of the Thermalright Si-128. I use them in 2 of my hFX systems. The only disadvantage in the Fusion is the case exhaust are on the side and the SI 128 fins are narrow and run vertically.
    Horizontal Fins make more sense in the Fusion. Consider the Scythe Ninja Mini using the 12cm case exhaust fan
    http://www.silentpcreview.com/article754-page5.html
    Gavin
