Ordering SKY+, how do I know which box I will get??
Discussion in 'Sky Digital TV Forum' started by DrMekon, Nov 2, 2004.
  1. DrMekon
    DrMekon
    Nov 2, 2004
    893
    28
    +41
    Is it just pot luck when ordring SKY+ (New subscriber) on which version and make receiver you will get??
    Obviously reading through many posts, it has become apparant that V2 boxes seem to cope with HD upgrade, although some V1 are also successful, due to sky software updates....
    As I will be upgrading the HD, almost as soon as the geezer has chipped off, I want to arm myself with the best materials...
    Any advice would be welcomed!!
  2. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    You won't get a V1. You'll get a V2 or more probably an Amstrad, both these boxes seem to upgrade ok.
